1997 Ford Taurus Rear Window Motor
BIGDFROMMN
I'm looking for some help with repairing a rear window motor on a 97 Taurus. Is this something a relative novice can handle or should I be looking for a professional mechanic to repair this? Thanks in advance for any advice.
Aug 17, 2007 at 12:16 AM
SERVICE WRITER
  • 9,123 POSTS
If your mechanically inclined and patient, give it a shot.
You'll still be able to close the door with the panel off if you run out of time. Worst case scenario is you have to take it in. Sometimes taking pictures can be beneficial as you remove things so you can look back to see how it was prior to disassembly.
We can help if you get into problems more than likely.
Aug 17, 2007 at 12:22 AM
Suggested Repair
If you are patient and mechanically inclined, try the rear window motor repair yourself. Photograph each step of door panel removal so you can reassemble it correctly, and note that the door can still be closed with the panel off. If you get stuck, take the car to a shop.
Conversation Summary
The owner of a 1997 Ford Taurus asked whether a novice could repair a rear window motor or should hire a mechanic. The expert said a patient, mechanically inclined person can attempt it, take pictures during disassembly, and still close the door with the panel off. If problems arise, the car can be taken to a shop.
