1995 Ford Taurus No Heat
DAVIDNOFFS
My sons car is a 1995 Ford Tarus, 3.0 Liter v 6. Car has 106,000 miles. The car only blows cold air no heat. Tempature gauge works wich leads me to believe it is not a thermostat. No smell of antifreeze inside the car or leaking, so do not think it is heater core. I just replaced water pump 2 months ago.
Any suggestions?
David.
Nov 4, 2007 at 3:07 AM
BLACKOP555
  • 10,386 POSTS
are the heater hoses going to the heater core both hot? if not then bleed the coolant system. may have a air bubble preventing antifreeze from going into heater core.
Nov 4, 2007 at 3:13 AM
SPOCK8113
My experience says the heater core is clogged. You may want to flush the core before you go ripping the dashboard apart. I just did this in my 2000 Taurus. I'm not saying they are all identical, but this seems to be a common problem.
Seems the heater core bypass pipe provides a path of lesser resistance for the anti-freeze. During the summer, while the heat is off, the scale and rust builds up and gradually blocks the coil.
here's a link to the pictures I took while flushing my Taurus this weekend:
http://s35.photobucket.com/albums/d170/spock8113/2000%20Taurus%20Heater%20Core%20Flush/
Once the heater core is flushed, I would recommend an entire cooling system flush to be sure all rust and scale is no longer present in the system. It seems that the water pump impeller can rust and deteriorate becoming a major source of coil-clogging debris.
This is the second time I’ve done this and the first time I’ve done a fully system flush.
Be sure the engine is COLD!
Now I have more heat than I know what to do with.
Figure about 3 hours to complete this coil flush - start to finish.
Good luck.
Nov 5, 2007 at 2:47 AM
Suggested Repair
Check whether both heater hoses to the heater core are hot. If not, bleed the cooling system to remove an air pocket. If flow is restricted, flush the heater core before removing the dashboard, then flush the entire cooling system to remove rust and scale.
Conversation Summary
A 1995 Ford Taurus 3.0L with 106,000 miles blows only cold air. The temperature gauge works, there is no antifreeze smell or leak, and the water pump was recently replaced. One reply advises checking heater-hose temperature and bleeding air from the cooling system. Another reports a common clogged heater core and recommends flushing the core, then the full cooling system.
