1996 Ford Taurus Hesitation and Leak
JBACK45
[color=blue:7a9735fc36][/color:7a9735fc36]
Hi I just purchase a 1996 ford taurus gl the car is in perfect condition. It only has 79,000 miles on it.Well the girl I bought it off of said the transmission is leaking and she was told she would need a new one. She never got a second oppion. My hopes are tHAT MAYBE IT COULD BE A SEAL OR GASET BECAUSE THE CAR SHIFTS PERFECT BUT IT LEAKS AND TRANNY FLUID IS CLEAN. sO ANYBODY HAVE ANY IDEAS WERE ITS COMMING FROM. tHERES ONLY DRIPS, NOT A HEAVY LEAK. aLSO WHEN I PRESS THE GAS PEDAL DOWN WHEN IN A COMPLEATE STOP. tHE CAR WILL HESITATE TO GO AND THEN WHEN I GET TO ABOUT 15 IT WILL START TO PICK UP SPEED BUT YET SEEMS LIKE IT WONT KICK IN ANY SUGGESTIONS. yET IF I DONT STOP LIKE A QUICK STOP AND GO THE CAR DRIVES FINE. ANY SUGGESTIONS :roll:
Mar 14, 2006 at 3:44 PM
RAYHUT
  • 134 POSTS
#1. your transmission - you might want to look to see if it's leaking in the front or back of the trans. if either you need to replace the seal(s)they are called front trans. seal and rear trans. seal. and if either doesn't work have it rebuilt.
#2. gas - you fuel injectors are cloged you either need to replace them or run some fuel injection cleaner through your gas tank to clean them.
Mar 14, 2006 at 9:43 PM
JBACK45
found out it is a crack in the casing of the transmission needs to be replace but can this be the problem for thenhesitation when i press the :cry: gass
Mar 16, 2006 at 2:53 AM
Suggested Repair
Check whether the transmission leak is at the front or rear seal and replace the leaking seal; if that does not stop the leak, have the transmission rebuilt. For hesitation from a stop, clean clogged fuel injectors with fuel-injection cleaner or replace them.
Conversation Summary
The owner of a 1996 Ford Taurus GL reported a light transmission-fluid leak with clean fluid and normal shifting, plus hesitation when accelerating from a complete stop that eased around 15 mph. An expert advised inspecting the front and rear transmission seals, replacing a leaking seal, and rebuilding the transmission if needed, and treating the hesitation as clogged fuel injectors by cleaning or replacing them. The owner later said the transmission case was cracked and needed replacement, and asked whether that caused the hesitation, but no further expert reply appears in the thread.
