Intermittent fuel pump problem - 2000 Taurus
KSTOECKLEIN
  • 5 POSTS
I have a 2000 Taurus, 104K miles, 3.0 DOHC engine, auto trans.
This situation has happened to me 4 times within the past 7 weeks, and seems to occur at random.
The problem (so far) typically occurs after a short drive (approx 5 miles), and after the car has sat for at least a few hours (as when driving home from work or shopping). I'll stop to pick up my mail at the apartment complex, shutting off the car for about 1-2 minutes. Then as I'm driving away, the engine dies and will crank but not start as if out of fuel. After letting the car sit for about 30 minutes or more, it will start and run normally. I have determined that after the engine dies, the fuel pump is not running, as I cannot hear it run-up when the ignition is turned on. When I do hear the fuel pump run-up, the engine starts fine. I have subsequently replaced the fuel filter and fuel pump relay (in fuse box under hood) and it would seem the only thing left is the fuel pump itself. I took it to a dealer and they were no help, since their diagnostic machine didn't see a fault code. I am hesitant to replace the fuel pump ($600 job!) unless I know for sure that this is the culprit and will solve the problem. Also, this does NOT happen only on very hot days, and the car has always had at least 1/2 tank of fuel when it occurred (these always seem to be suggested causes).
Is there anything else that could cause an intermittent fuel pump failure? It seems to me that if the fuel pump were bad, it would be more obvious and just stop running for good.
Oct 20, 2007 at 9:20 AM
MERLIN2021
  • 17,250 POSTS
You may have a simple to solve issue, it sounds as if your radiator fins a clogged to the point of causing your fuel to boil in the rail, you need to follow this link and this advice, also make sure your cooling fans work! The give away on this is it only happens on very hot days..
https://www.2carpros.com/forum/2003-sable-stops-at-hwy-speeds-when-hot-outside-vt35632.html
Oct 20, 2007 at 10:06 AM
KSTOECKLEIN
  • 5 POSTS
This is not the problem as it does NOT occur only on hot days (see original post). When the problem occurs, the fuel pump is definitely NOT running, so it is something causing interruption of the fuel pump power, or maybe the fuel pump is wearing out, but my intuition is that the fuel pump would not just occassionaly decide to shut off if it were bad. Seems to me that a bad fuel pump would stop running altogether, not once every few weeks.
Oct 20, 2007 at 10:23 AM
MERLIN2021
  • 17,250 POSTS
If you are handy at tracing wires, you can look were the wires run behind the left inner fender, My 99 fuel pump wire chaffed all the way thru at that spot...might be grounding there intermittently.
Sorry about this miss! I read a boatload of posts and sometimes I try to get more than my share!
Oct 20, 2007 at 11:37 AM
GOLFCATS122
I had same problem. 2000 Taurus w/101,000 miles.
Check the EMERGENCY FUEL SHUT OFF SWITCH located in trunk, right side, under felt (under decal).
Jumpered out switch & fuel pump started (so did car).
Oct 20, 2007 at 2:32 PM
MERLIN2021
  • 17,250 POSTS
Inertia switch tripped would be a constant, not intermittent problem!
Oct 20, 2007 at 11:15 PM
GOLFCATS122
Switch is not "tripped", it's defective. After it cools off, circuit is closed, fuel pump runs, and car starts.
Oct 27, 2007 at 4:14 PM
KSTOECKLEIN
  • 5 POSTS
Update........ Looks like it was the fuel pump after all. Had it replaced several weeks ago and haven't had a problem yet. I don't mind spending the money for a fuel pump, but just wanted to be sure it was the right solution. After determining that there was power going to the fuel pump even when the problem existed, I was pretty sure it must be the pump. My guess is that there's a pressure sensor in the pump that cycles on/off the motor that must have been going bad. Does this sound right to any knowledegable Ford mechanics out there?
So...... I'm good to go, and I hope this will help someone else down the road.
Thanks for everyone's input.
Dec 1, 2007 at 6:19 AM
MERLIN2021
  • 17,250 POSTS
Pressure regulator is on the fuel rail, it returns unused fuel to the tank, pump will run all the time when car is running...
Dec 1, 2007 at 6:28 AM
KSTOECKLEIN
  • 5 POSTS
That would be logical, but why does the pump shut off when the ignition is turned on and the engine not yet cranked over (with good pump) if there's no pressure shutoff to the pump motor? What then might cause the pump to shut off and not restart after first starting the engine, then run again after sitting for a few minutes (when it had the problem), but not stop running at any other time while driving normally?
Even though it's fixed, I'd like to understand what could've caused the problem, and why a new fuel pump cured it. It couldn't be the pump motor getting hot, because the problem would occur even if the engine was stone cold, and it only happened within 30 seconds after starting the engine.
Thanks
Dec 3, 2007 at 3:05 PM
MERLIN2021
  • 17,250 POSTS
You have a relay thats powered for 2-3 secs, enough to pressurize the fuel system until it's started...
Dec 4, 2007 at 6:08 AM
KSTOECKLEIN
  • 5 POSTS
Do you have an idea of why the pump would start and then shut off a few seconds later, only to restart after sitting for up to 30 minutes? (I don't think the car will start without initial fuel pressure, will it?) To me, this sounded like a relay or something not energizing, but I proved that the relays weren't the problem. Also this would only happen after initial start and not during continuous operation, until the car was shut off and restarted again (but only on random occassions). Seems like there must be something in the pump tied to the initial start conditions that would turn off power to the pump. When the situation occurred, the pump could not be heard to run when the ignition was turned on, until the car sat for a while. Then, I'd turn on the ignition, hear the pump, start the car and drive away. Sorry to be a pain, but I'm the inquisitive type just not happy to know that it needed a fuel pump.........
Dec 4, 2007 at 10:38 AM
MERLIN2021
  • 17,250 POSTS
Are you asking about the old, defective pump? It must have had a dead spot on the windings in the motor, or loose wire internally...
Dec 5, 2007 at 5:34 AM
