heating/cooling
BRICK
1999 ford taurus[145,000mi]v-6DOHC
Hello,I start up from cold eng.and the low coolant light comes on and stays on for the duration of the drive[the reservoir is kept filled to the proper level].
After driving for 15 min. the temp. gauge is higher than normal but the car is not boiling.Sometimes the
check eng. light comes on -when this happens the car runs properly and all gauges read normal and the heat works fine but when the light goes out their is no heat and the a/c seems to be active even when I set the temp in the car to 90 degrees.
Any help would be appreciated!
Signed: going out of wits
THANK YOU EVER SO MUCH FOR YOUR HELP.
Sep 2, 2007 at 7:57 PM
  • 75,988 POSTS
[quote:7eb335ff89="brick"]1999 ford taurus[145,000mi]v-6DOHC
THANK YOU EVER SO MUCH FOR YOUR HELP.[/quote:7eb335ff89]
The brain (PCM) has detected a problem within the engine's electronic controls -to provide you with additional assistance you need to have the OBD2 system scanned for code/s and comeback with it.
Sep 2, 2007 at 8:17 PM
JOESAL
I have a 1999 Taurus 3.0 OHV and I cannot get the heat to come on also.
I have just replaced the water pump at 134,000 mi.
the SES light was on and the temp gauge was running hot. I could not find the source of coolant loss but finally saw a trickle out of a weep hole in the water pump.
I ran the car for a while yesterday but when I turn the ac off and turn the heat on it still blows cold ac air out of the vents unless I have the switch set to off. Any other setting and the air compressor still runs.
Sep 2, 2007 at 9:18 PM
  • 75,988 POSTS
[quote:745a0fbbc0="joesal"]I have a 1999 Taurus 3.0 OHV and I cannot get the heat to come on also.
I ran the car for a while yesterday but when I turn the ac off and turn the heat on it still blows cold ac air out of the vents unless I have the switch set to off. Any other setting and the air compressor still runs.[/quote:745a0fbbc0]
Coolant coming out of the water pump weep hole is a sign of a bad water pump-sooner or later its gonna come out like Mississippi River and you'll be in big time trouble with major repairs. Get it taken care of
Sep 2, 2007 at 9:54 PM
