1999 ford taurus[145,000mi]v-6DOHC
Hello,I start up from cold eng.and the low coolant light comes on and stays on for the duration of the drive[the reservoir is kept filled to the proper level].
After driving for 15 min. the temp. gauge is higher than normal but the car is not boiling.Sometimes the
check eng. light comes on -when this happens the car runs properly and all gauges read normal and the heat works fine but when the light goes out their is no heat and the a/c seems to be active even when I set the temp in the car to 90 degrees.
Any help would be appreciated!
Signed: going out of wits
THANK YOU EVER SO MUCH FOR YOUR HELP.
Sep 2, 2007 at 7:57 PM
