1992 Ford Taurus Headlamp Bulb Access Fix
LOLAROXX
1992 Ford Taurus Wagon w/ no options or extras
this is a very simple question however, i do not have a repair/service manual.
The driver side side headlamp lowbeam has gone out.
How in the heck do i access the $%@^ bulb to replace it? i know how to replace it i just cannot get to it. What needs to removed the front panel? do i go from looking down at the head lamp when the hood is open?do i access it from the rear and if so what needs to be moved so i can reach it?
Help- i need to do this tonight before 0100. it is now1952. i hope you have enough info from me re: this.
Jan 14, 2007 at 2:00 PM
INDYUKE
  • 416 POSTS
Yes, you do access it from the rear. There should be enough room to squeeze your hand down just behind the headlamp, give the bulb bracket a 1/4 turn and pull it out. Sometimes it's a real drag. I hope this helps. This video will help you see how the job is done.
https://youtu.be/BxjAoUtN-qw
Please go over this guide and report back.
Jan 14, 2007 at 3:12 PM
Suggested Repair
With the hood open, reach behind the headlamp from the rear. Turn the bulb bracket a quarter turn and pull the bulb out.
Conversation Summary
The owner of a 1992 Ford Taurus wagon could not reach the failed driver-side low-beam bulb and asked whether the front panel or other parts had to be removed. The expert said the bulb is accessed from behind the lamp by reaching in, turning the bulb bracket a quarter turn, and pulling it out, and linked a video of the job.
