Headlamp bulb replacement
LOLAROXX
1992 Ford Taurus Wagon w/ no options or extras
this is a very simple question however, i do not have a repair/service manual.
The driver side side headlamp lowbeam has gone out.
How in the heck do i access the $%@^ bulb to replace it? i know how to replace it i just cannot get to it. What needs to removed the front panel? do i go from looking down at the head lamp when the hood is open?do i access it from the rear and if so what needs to be moved so i can reach it?
Help- i need to do this tonight before 0100. it is now1952. i hope you have enough info from me re: this.
Jan 14, 2007 at 2:00 PM
INDYUKE
  • 416 POSTS
Yes, you do access it from the rear. There should be enough room to squeeze your hand down just behind the headlamp, give the bulb bracket a 1/4 turn and pull it out. Sometimes it's a real drag. I hope this helps. This video will help you see how the job is done.
https://youtu.be/BxjAoUtN-qw
Please go over this guide and report back.
Jan 14, 2007 at 3:12 PM
