have no idea whats wrong
JILLER1966
i have a 92 ford taurus...almost 200,000 miles...3.0.....have had the car in the shop three times [two different shops] they have replaced the fuel filter, and done a tune up ..still having the same problem......if we crank the car early in the morning ...around 6 am...it will run for a few min...then start spitting and sputtering..then dies....let it sit for 30 min or so..the car will crank up and then run fine...only have problems in the early morning...or if it is raining...the two shops have no idea..i am a single mom of two..cant afford to have the shops keep putting parts on that isnt going to fix the problem...have been told it could be the maf..iac...coil...or fuel pump...any ideas? if so..is any of this i can do myself? thanks for your help :?:
Oct 22, 2007 at 4:17 AM
SERVICE WRITER
  • 9,123 POSTS
Since the problem happens when it's raining, I would lean toward an ignition problem, What was done on the tune up? Wires?
Try spraying/misting water on the areas from the plugs, up on the wires and to the coil and see if any rough running occurs during this. Do this while the engine is running.
Oct 23, 2007 at 2:49 PM
