1999 Ford Taurus ABS Light and Tight Brakes
Anti-Lock Brake Indicator On After Vehicle Starts to Move or False Cycling of Anti-Lock System
Possible Source(s):
§ Circuit.
§ Sensor.
§ Anti-lock brake control module.
Action(s) to take:
§ RETRIEVE DTCs. REPAIR as necessary.
Suggested Repair
Have the ABS system scanned for stored codes before replacing parts. Check the wheel-speed sensor circuit and ABS control module if a code points there. For brakes that tighten after driving, open the bleeder at the affected wheel while tight: if the wheel then turns freely, replace the collapsed brake hose; if not, continue diagnosing the hydraulic system.
Conversation Summary
A 1999 Ford Taurus owner reported the ABS light coming on after driving and the brakes becoming very tight after about five minutes. Calipers, pads, and lines had already been replaced and the system bled, but a scan reportedly produced no code. Experts advised confirming which wheels were serviced, retrieving ABS diagnostic codes, and isolating the tight wheel by opening its bleeder to distinguish a bad hose from another hydraulic fault. Possible ABS causes mentioned were a circuit, wheel sensor, or control module.
