electrical 99 Ford Taurus
MIDMOGUY14
I own a 99 Taurus with 130,00 miles--I noticed the car was taking a bit longer to start and took it in for a battery check. They checked the 4-year old battery--said it was good, rechecked, said it was bad. Replaced battery and car wouldn't start. Then, replaced starter (hadn't noticed problem before) and car started. When picked up car, remote keyless lock would not work although power locks in car work. Replaced battery in remote entry keychain--still no remote keyless lock. When I drove off, I discovered the front left headlight didn't work. One or two of these could be coincidental--all of it doesn't. Need fix. Thanks.
Apr 28, 2007 at 2:25 PM
MERLIN2021
  • 17,250 POSTS
Have you tried replacing the bulb for the headlight? Take neg cable off for a few mins...if the positve cable was hooked up last could cause problem...
Apr 28, 2007 at 2:30 PM
2CARPRO JACK
  • 11,533 POSTS
Is that a factory alarm system? It is possible for a starter that is drawing too many amps to create undo strain on the battery, causing it to fail. Check to see if the shop flipped the "valet" switch on the alarm if it is an aftermarket
Apr 29, 2007 at 1:42 AM
