97 Taurus 3.0,133000 miles.The cruise light comes on but when the set button is pushed nothing happens.Is this an easy fix?
Oct 20, 2007 at 9:28 AM
MERLIN2021
✓Experienced Mechanic
The easiest will be if it's the deactivation switch on the master. also check your brake lights, are the stuck on?
Oct 20, 2007 at 9:30 AM
PHILBERT1998
MEMBER
[quote:881fd28f6d="philbert1998"]97 Taurus 3.0,133000 miles.The cruise light comes on but when the set button is pushed nothing happens.Is this an easy fix?[/quote:881fd28f6d]
I figured it out.The connector on the end of the cable that comes from the control unit was unhooked.It is covered by a plastic shield that needs to be removed to gain access.
