I recently had my 2000 Taurus SES DOHC (109,000 miles) serviced for cold stalling. According to the invoice they repaired PCM replaced IAC and vacume hose and upgraded the computer. Still having same problem. When I start the car in the morning it stalls within 10 seconds. It will continue to stall when stopped until its been running 20 minutes or so then it runs fine. Now the engine light is on when it never was before. When i brought it back they performed self test and retrived DTC P0171 and pending DTC p0174. they also perf. smoke test and found lower intake gaskets were leaking. i have sort of lost confidence in this mechanic and i am reluctant to have it serviced again and it not be fixed. Will fixing the gaskets take care of my problem.
Jan 11, 2007 at 12:52 PM
