1990 Ford Taurus Battery Acid Leak
RICKSWIFE07
My son has a 1990 ford taurus 3.0 with 150,000 miles on it. About a month ago we had to start disconnecting the battery or it would not start after sitting. Then the battery started leaking acid out of it so we replaced it. It started fine for a few days then we had to jump it again. So then we had the alternator checked, it was bad, and we replaced it. Still no luck he still had to disconnect. The new battery is only 1 week old and it started leaking acid again. Any ideas what it could be?
Oct 24, 2007 at 10:29 AM
BMRFIXIT
  • 19,053 POSTS
[quote:a1077e0449="rickswife07"]My son has a 1990 ford taurus 3.0 with 150,000 miles on it. About a month ago we had to start disconnecting the battery or it would not start after sitting. Then the battery started leaking acid out of it so we replaced it. It started fine for a few days then we had to jump it again. So then we had the alternator checked, it was bad, and we replaced it. Still no luck he still had to disconnect. The new battery is only 1 week old and it started leaking acid again. Any ideas what it could be?[/quote:a1077e0449]
Leaking acid mean the battery is been over charged
Check the charging system
Actually you need to check the electric system
Something staying on discharging the battery
Draw test need to be done on it
Let us know if more detail needed
Or help
Good luck
Oct 24, 2007 at 12:07 PM
Suggested Repair
Check the charging system for overcharging, which can cause battery acid leaks, and perform a parasitic draw test to find anything staying on and discharging the battery.
Conversation Summary
A 1990 Ford Taurus 3.0 with 150,000 miles would not start after sitting unless the battery was disconnected. The battery leaked acid and was replaced, then a bad alternator was replaced, but the new battery still drained and began leaking acid within a week. The expert said acid leakage indicates overcharging and recommended checking the charging and electrical systems and performing a draw test for a component that stays on.
