air cond. problem
ARCHER1
I have a 2005 ford Taurus. 3.0 liter w/66,000 mi.
The air cond. comp. will just
stop running when ever it feels like or does not come on at
all. If i keep messing with the knob it eventually comes on.
It's not a freon problem because when it runs it will freeze
you out of the car. Could it be a sensor problem or a switch
problem. How do I determine what's going on?
Sep 4, 2007 at 9:45 AM
MERLIN2021
  • 17,250 POSTS
2 things you really need to check, hook up a set of manifold gauges and take the readings, not the temp and humidity at the time. then turn the system on and get the readings, with a/c on max, count how long the clutch stays on for, between cycling. Is the system a/c or temp control?
Sep 4, 2007 at 9:55 AM
