The windshield washer nozzles are pointing too low on my 99 Taurus. How do I adjust them?
Feb 7, 2006 at 7:12 AM
BUSHBJ
MEMBER
i am having the sme problem as you are. it just happened to me recently. have you had any luck in fixing it yet? if so let me know!!!
bushbj2002@yahoo.com
May 1, 2006 at 7:51 PM
JNACHTRIEB
MEMBER
I mis-diagnosed the original problem. Problem was squirter aimed too low, due to low water pressure. SOlution turned out to be dry rot on feed hose from talk (or pump) to squirters. I replaced the rotted section and all is well.
