1998 Ford Taurus Engine Swap Calibration
but you're saying that it's not the same engine? i know people change the engines in cars all the time, i figured as long as the engine fits, it's all good, especially since it seems like it's pretty much the same engine. i don't need to pass an emissions test i don't think, but i don't want to spend money doing this if it only half-assed runs. thanks for the help.
i only need an A to B vehicle right now until i graduate in a year, i really only want to get by with spending as little as possible and i'm basically hoping that i can get a working vehicle this way for less then buying another car. my other option that i'm favoring is a '91 honda civic for a lil under 2K. looks like i'll have to do that if my engine swap scheme will result in a car that runs like crap.
Each vehicle has a decal (Figures 1, 2 and 3) containing emission control information that applies specifically to the vehicle and engine. The specifications on the decal are critical to servicing emissions systems.
In addition to the tune-up specifications and procedures, the emission decal shows a color-coded (shown in black and white) schematic of the engine vacuum system. The color coding on the schematic represents the actual color coding on the vacuum hoses. However, there will be instances when a hose color does not match the color on the decal.
Decal Location
Typical location of the decal will be on the underside of the hood or the radiator support sight shield.
Powertrain Base Calibration Information
Powertrain Base Calibration Information is located in the lower right corner of the Vehicle Certification Label. Only the Base Calibration will appear on this label (Figure 3). The Revision Level is no longer printed on the label, however it can be found in On-Line Automotive Service Information System (Oasis). For the 1999 model year Ford Motor Company is using two different Protocols which describe Powertrain Base Calibration. The Protocols are designed to provide worldwide standardization for vehicle calibration. If electronic engine control strategy is carried over to the 1999 model year from 1998, Protocol 1 is used (see Table 1 below). New strategies for the 1999 model year use Protocol 2 (see Table 2 below). For more information on Vehicle Certification Label, refer to the Workshop Manual.
Figure 3: Typical Vehicle Certification Label with Powertrain Calibration Information
Decal Location
Typical location of Vehicle Certification label is on LH door or door post pillar.
I would guess that it's certainly probable that the car would run, not saying it would run like crap, only the chance that it's going to possibly create some headaches where in the end you would have wished you hads purchased a complete ready-to-run vehicle.. if you don't have the need to pass emission testing for vehicle inspection or whatever, that's a plus in your favor...
Suggested Repair
Before swapping the 1999 3.0L Vulcan into the 1998 Taurus, compare emission calibration codes on both engines and the vehicle certification labels, then confirm with a Ford dealer that the 1998 PCM can control the donor engine. Matching mechanical size alone does not guarantee optimal operation; mismatched calibrations can cause drivability or emissions problems.
Conversation Summary
The owner asked whether a good 3.0L engine from a wrecked 1999 Ford Taurus could be installed in a 1998 Taurus with a thrown rod, and what a shop transfer might cost. The expert said the engines can be the same mechanically but may have different emission calibrations, so the receiving car's powertrain control module may not control the donor engine optimally. The owner confirmed both are 3.0L SFI Vulcan V6 engines and wanted only basic transportation. The expert advised checking calibration decals and consulting a Ford dealer, noting the car might run without emissions testing but could still create headaches.
