97' Ford Taurus G 3.0L V6, 188K Trunk Lock Won't Turn
1997 FORD TAURUS
THEBIGMAN103
As you might or might not know this perticular Taurus does not have a trunk release anywhere else(at least that I have found In 8 years). When you stick the key in to try to open the trunk it will not turn we have also tried the spare key in case of ware n' tare on the key but still nothing a friend of ours suggested graphite and WD40. Will that do it or will it take more drastic measures. Thank you for your time.
Feb 24, 2007 at 11:16 AM
CHEVY22
  • 1,375 POSTS
hi
im sorry if this sounds stupid but it does work on some locks , try inserting the key and jiggle up and down and side to side while turning the key , you may also want to try to put some pressure on the hatch while doing the above ,let me know if my dumb trick worked
thanks jim
Feb 24, 2007 at 11:53 AM
