96 ford taurus ac fan won't turn on
INTENSITYX
I have a 96 ford taurus V6 with around 90k miles on it. When I shut off the engine the AC fan did not turn off (it kept running). I turned the engine on and then off again and the fans turned off. When I started the car up again I had no fans. I can tell that the AC is still working, but there is just no air in the car. I have checked fuses, but the manual the car came with doesn't really go over this problem. Any ideas?
Jul 14, 2007 at 5:01 AM
INTENSITYX
When you turn the fan controls near the radio, that fan is not blowing through the vents. There is no air or heat in the car right now.
Thanks
Jul 14, 2007 at 5:16 AM
