94 ford taurus power door locks don't work
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Provide the recorded switch-test findings and clarify whether any lock movement or sound had been observed during the failures.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
good luck.
Discussion summary
The owner of a 1994 Ford Taurus reported that the power door locks did not work from either the driver or passenger side. The owner had no keyless remote and reported checking the fuses and checking a switch with a meter.
Reported outcome: The owner did not report a completed repair or resolution.
The meter readings and exact scope of the switch check were not supplied. A reply suggested an actuator, but no findings confirmed a failed component. A separate remote-programming suggestion did not address the owner’s stated lack of a remote.
