93 Taurus GL 3.8L engine Power Seat Problem
KENK67
The Power seat switch on my 93 Ford Taurus is not working properly. I can move the seat up and Down, but not forward and back. Is there a way to manually get the seat to move forward until I can get the switch replaced. any suggestions would be greatly apprediated.
Ken
Jul 16, 2007 at 10:36 AM
KENK67
[quote:5373b98c04="justanold"]HELLO! No you can't do it manually. easy test..engine off.. interior light on..try to move the seat back while observing the light..now try moving forward and observe the light. did the light dim in either direction? let me know. 8) 8) 8)[/quote:5373b98c04]
The light did not dim when I tried moving the seat in either direction
Jul 16, 2007 at 11:54 AM
KENK67
[quote:6c06686224="justanold"]HELLO! I believe you will find that the problem is your seat track assy. and not the switch. the track comes with the motors attached. check prices new VS used and go from there. 8) 8) 8)[/quote:6c06686224]
Thank you very much for the info. I appreciate the assistance
Jul 16, 2007 at 12:08 PM
