1993 Ford Taurus floor lights switch
150,000 MILES • 6 CYL • FWD • AUTOMATIC
SDAVIS0510
The light under the glove compartment (on the floor) remains on while all doors properly closed. Unable to locate the on/off switch for this light in the owner's manual
Nov 19, 2009 at 1:40 PM
  • 110,251 POSTS
It should shut off with the dome light. Somewhere in the wiring, you have a short that is either providing power to it, or there is a ground problem and a different component is backfeeding power through the light to gain a ground. The only thing you can do is start checking for a wiring problem. Follow the power supply to the light looking for a damaged wire.
Let me know what you find.
Nov 19, 2009 at 2:47 PM
