1987 Ford Taurus Shuts Off Randomly
SCOOTT66
My dad has an ’87 Ford Taurus (automatic) with about 90,000 miles on it. A few months ago it started shutting off while driving. In the beginning it would stall at an intersection and then start right up. He took it to the mechanic and had it fixed. Shortly after, it started turning off while driving (as if you turned the key off). It doesn’t matter how fast you are going. 50 or 15 mph it doesn’t care. If you pop it into neutral it will start right up. If you leave it in gear, it locks and you are stuck. This happened erratically. It will be fine for a week and then one day it might happen 6 or 7 times. He took it to a mechanic and was told that it was the transmission. He then took it to a transmission shop and was told that there was absolutely no way it was the transmission. It had to be something electrical. Going back to the mechanic, he was again told it was the transmission. The big problem is that it will never do it when you want it to (big surprise). We even left it with the mechanic for a week. So neither the mechanic nor the transmission guy has seen it in action. Do you have any suggestions? Thanks.
Aug 25, 2006 at 11:38 AM
TAURUSWHEEL
  • 718 POSTS
Was it scanned for codes??? Check enginre light not on doesn't mean that an issue may not exist,,, there was a problem with the tfi sensor failing when hot, however the issue of always starting in neutral doesn't fit with that,, it's possible your torque converter isn't unlocking as you're slowing down or stopped, that would cause the engine to stall.. I would have it scanned, hopefully something will show..
Aug 26, 2006 at 12:44 AM
SCOOTT66
I will check. Thanks for the tip.
Aug 28, 2006 at 4:23 PM
Suggested Repair
Scan the vehicle for diagnostic codes even if the check engine light is off. A hot-failing TFI sensor is a known possibility, but easy restarting in neutral does not fit that well. Also check whether the torque converter clutch fails to unlock when slowing or stopped, which can stall the engine.
Conversation Summary
A 1987 Ford Taurus with about 90,000 miles stalls randomly while driving, as if the key were turned off, at any speed. It restarts immediately in neutral but locks up if left in gear. Mechanics disagreed over whether the cause was the transmission or electrical, and the problem never occurred during inspection. The expert recommended a code scan, noted a possible hot TFI sensor failure that may not fit the neutral-start symptom, and suggested checking torque converter unlock.
