2007 Ford Taurus stalling
50,000 MILES • 6 CYL • FWD • AUTOMATIC
JOURNY5
I have a 2007 ford taurus. The car trys to stall and die taking off from a stop light. Runs rough and acts likes its running out of gas. The only code i have gotten from it was po191. I have already replaced the fuel filter and the fuel rail pressor sensor. Has this been a common problem on the taurus. This only happens once a day for a few minutes.
Aug 4, 2010 at 9:45 AM
  • 75,988 POSTS
Check and test the EGR valve, MAF and TPS sensors-to include the fuel pressure
Jan 21, 2018 at 4:35 AM
JOURNY5
The car will only act up when it is at normal operating temp. and the fuel is less than 1/4 tank. Not sure if that will help too.
  • 75,988 POSTS
Have you checked and tested the above mentoned as suggested? Were not gonna throw parts at it. You need to troubleshoot
