2006 Ford Taurus Sharp turns causes car to die
RICKREEVES
  • 2006 FORD TAURUS
  • 6 CYL
  • FWD
  • 60,000 MILES
This has happened 3 times in a year. While making a sharp right or left turn the car engine dies. Once you get stopped, you can start the car right up. Car runs fine other than this problem. No codes are showing, no warning lights are on.
Tuesday, October 12th, 2010 AT 4:09 PM
  • 109,885 POSTS
The only thing I have found that causes this type of problem is either a partially plugged fuel filter, weak fuel pump, or a wiring issue. The bad part is this. Most likely, you won't find the problem until it gets much worse.
Wednesday, October 13th, 2010 AT 12:04 PM
