2006 Ford Taurus my lights are still flickering and my rpm'
2006 FORD TAURUS
TRAE WHITE
2006 Ford Taurus 6 cyl Front Wheel Drive Automatic
My lights are fickering still and my rpm's are still not steady but my check engine light is not on. My rpm's go up and down from about 700rpm and 850rpm and rough idles a little bit during my lights flickering. I put new sparkplugs, a new fuel filter and i change the oil. I had my altenater tested it tested good and i also cleaned the battery terminals and tightend. I was wondering what my problem could be after all that?
Oct 28, 2009 at 9:39 AM
BMRFIXIT
  • 19,053 POSTS
Have to check for pending codes
check for vacuum leaks
check MAF sensor and clean idle
Oct 28, 2009 at 2:55 PM
