2006 Ford Taurus misfiring
100,191 MILES • 6 CYL • FWD • AUTOMATIC
MICHAELYN
I have replaced the fuel filter in this car, and it still misfires. What else could be causing this to happen?
Feb 12, 2010 at 5:21 AM
LEGITIMATE007
  • 5,121 POSTS
misfires can be caused by many things, among those are, vacuum leaks, half open egr valve, fouled plugs, wires, clogged catylitic converter. clogged air intake. check those one by one, and easy way to check for vacuum leaks is to spray brake kleen, around the vacuum hoses and intake manifold, when the idle changes, there is your leak.
Feb 12, 2010 at 5:50 AM
