2006 Ford Taurus fading
2006 FORD TAURUS
208,000 MILES • 6 CYL • FWD • AUTOMATIC
PNP153
The steering seems to fade when you are turning. Sitting with the engine running I can turn the steering wheel and hold it, the wheel then will release a little and then firm back up. When you are driving it will do the same thing. There is plenty of fluid and I watched the level while the wheel was held there was no change. It almost acts like the is air in the line. Any thoughts on this problem would be greatly appriciated.
Aug 13, 2009 at 6:57 AM
BMRFIXIT
  • 19,053 POSTS
Check belt and belt tensioner
suspect rack and pinion
Aug 16, 2009 at 11:14 PM
