2006 Ford Taurus Electrical Problems
48,000 MILES • 6 CYL • FWD • AUTOMATIC
AJB71879
This morning when I started my car it turned over and started, but the interior lights and the heater would not function at all. What could this be caused by?
Jan 3, 2008 at 4:40 AM
  • 31,937 POSTS
Thank you for your donation.
Start with simple things first, check fuses, also has there ever been an issue with the heater or lights before? I will have a look at the schematic drawing and see if there is anything in common with the circuits. report back if fuses are ok. the only thing i can think of straight away, is that they both may be controlled by the same body control module, if so they may set a fault code, look at that as well.
Mark (mhpautos)
Jan 3, 2008 at 12:54 PM
