Daytime running lights?
55,000 MILES • 6 CYL • FWD • AUTOMATIC
FLYBOYZII
I have a 2006 Taurus that has the daytime running lamps. I want to disconnect that feature. If I pull the fuse...the headlights do not work at all because the DRL is tied into the headlamp switch. Is there an easy way to disconnect the DRL while everything else will work normally ??
Feb 24, 2009 at 3:28 AM
BMRFIXIT
  • 19,053 POSTS
The DRLs are controlled by the smart junction box (SJB) by operating the low beam headlamps at a reduced intensity. The DRL driver (integral to the SJB) supplies pulse-width modulated (PWM) voltage, approximately 75%-92% of battery voltage, to the low beam headlamps when the following conditions are met:
 The ignition switch is in the RUN position.
 The high beams are not illuminated.
 The parking brake is not engaged
so if you need to have them off set the parking brakes
Feb 24, 2009 at 9:09 AM
MEMAP1683
My Ford Taurus DRL have stopped working. When the switch is turned all the way to the left only the small yellow lights turn on. When evening time comes I have to manually turn the headlights on. Please help. Thank you.
Aug 15, 2020 at 3:56 AM (Merged)
MERLIN2021
  • 17,250 POSTS
Can be the headlamp switch, the GEM, or the multi-function switch or wiring/fuses, scan it for "B" codes before you begin this will pin point the area of the fault. TEST C: HEADLIGHTS INOPERATIVE WITH AUTOLAMPS ON 1. Turn headlight switch to ON position. If headlights operate, go to next step. If headlights do not operate, repair headlight system. See HEADLIGHTS in appropriate SYSTEM WIRING DIAGRAMS article in ELECTRICAL. 2. Turn ignition switch to LOCK position. Disconnect headlight switch 12-pin harness connector C205a, located on left side of dash panel. See Fig. 1 . Turn ignition switch to RUN position. Using WDS or NGS tester, command headlights ON. Measure voltage between ground and headlight switch harness connector C205a terminal No. 9 (Red/Yellow wire). See Fig. 4 . See WIRING DIAGRAMS . If any voltage exist, go to next step. If voltage does not exists, go to step 6 . 3. Turn ignition switch to LOCK position. Disconnect Central Junction Box (CJB) 36-pin harness connector C270b, located under left side of instrument panel. See Fig. 1 . Measure resistance between headlight switch harness connector C205a terminal No. 9 and CJB harness connector C270b terminal No. 32 (Red/Yellow wire). See Fig. 4 and Fig. 7 . See WIRING DIAGRAMS . If resistance is less than 5 ohms, reconnect CJB harness connector C270b and go to next step. If resistance is 5 ohms or more, repair open circuit in Red/Yellow wire between headlight switch and CJB. After repair, clear DTCs and test system for normal operation. 4. Remove fuse No. 29 (15-amp) from Central Junction Box (CJB), located under left side of instrument panel. See Fig. 1 . Disconnect GEM harness connector C201d. See Fig. 8 . Turn ignition switch to RUN position. Measure voltage between ground and GEM harness connector C201d terminal No. 25 (CJB side). See Fig. 8 . See WIRING DIAGRAMS . If any voltage exists, repair or replace CJB as necessary. If no voltage exists, install fuse No. 29 and go to next step. After repair, clear DTCs and test system for normal operation. 5. Disconnect CJB 36-pin harness connector C270b, located under left side of instrument panel. See Fig. 1 . Connect a 10-amp fused jumper wire between ground and GEM harness connector C201d terminal No. 25 (CJB side). See Fig. 8 . Measure resistance between ground and CJB harness connector 270b terminal No. 32 (CJB side). See Fig. 7 . See WIRING DIAGRAMS . If resistance is less than 5 ohms, reconnect all harness connectors and go to next step. If resistance is 5 ohms or more, repair or replace CJB as necessary. After repair, clear DTCs and test system for normal operation. 6. Disconnect all GEM harness connectors. Inspect for corrosion or pushed out pins. Repair or replace connectors terminals as necessary. See WIRING DIAGRAMS . Reconnect all GEM harness connectors, ensuring they are connected correctly. Operate system and verify if concern is still present. If concern is still present, replace GEM. See GENERIC ELECTRONIC MODULE under REMOVAL & INSTALLATION. If concern is not present, system is operating correctly at this time. After repair, clear DTCs and test system for normal operation. Fig. 7: Identifying Central Junction Box Harness Connector C270b Terminals Courtesy of FORD MOTOR CO. Fig. 8: Identifying Generic Electronic Module Harness Connector C201d Terminals Courtesy of FORD MOTOR CO. NOTE: Perform all voltage and resistance tests using a Digital Volt-Ohm Meter (DVOM) with a minimum 10-megohm input impedance, unless stated otherwise in test procedure. Use an ohmmeter to isolate wiring harness shorts or opens. Page 1 of 1 AUTOLAMP SYSTEMS -2001 Ford Taurus SE 9/6/2008
https://images.2carpros.com/forum/automotive_pictures/62217_1_4.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_CJB_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_GEM2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_GEM3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Gem_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_HSW_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Head_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Photo_1.jpg
MEMAP1683
At the bottom of the answer you gave me a webpage to also look at. When I tried to open the link I was told there was an error on the page and the rest of the page is blank. Can you resend this to me and make certain that it is working before you do? Thank you.
MERLIN2021
  • 17,250 POSTS
Thats not an actual link, it's a credit to Mitchell1 on demand...use the very bottom link to get a manual for your car...https://www.2carpros.com/kpages/auto_repair_manuals.htm
BWRIGHT
  • 5 POSTS
Electrical problem
1999 Ford Taurus V8 Automatic 45000 miles
my 1999 ford taurus daytime running lights blink. how to correct this problem
  • 110,251 POSTS
Is it a constant blink or only over bumps...?
BWRIGHT
  • 5 POSTS
The running lights only blink when the car is first turned on and lasts for about 10 minutes before they stop blinking. Also they may intermittently blink when driving.
Also I was incorrect my Taurus is not a V8 but a V6 SL model.
  • 110,251 POSTS
That is okay about the engine. They never made a V8 for one so I knew what you ment. As far as the lights, it sound tied into the vehicle security system. Have you ever noticed the security light staying on?
BWRIGHT
  • 5 POSTS
Thank you for your quick response, but the vehicle is not equipped with a security system.
NHOWARD76
I sometimes find that my wipers come on when my signal switch is turned on but also sometimes it comes on all by itself. I have also found that sometimes my daytime running lights will flicker, or sometimes when I use high lights at night they will flicker until I put on my dim lights again. Can you tell me what is the cause of it and how can I fix it. Thanks
MERLIN2021
  • 17,250 POSTS
Sounds like the multifunction switch itself has problems...
Aug 15, 2020 at 3:57 AM (Merged)
  • 110,251 POSTS
Are you sure? Most came factory with one. Have you ever noticed a theft light flashing? It is a very quick flash when the engine / key are off.
BWRIGHT
  • 5 POSTS
Thank you so much for your persistance. Since my husband drives the car most of the time, I can truly say that I have not seen the light you are referencing. I will check with him and email you back again.
  • 110,251 POSTS
Let me know. It was a few years back, but I thought it came from the factory with one.
BWRIGHT
  • 5 POSTS
Jacobandnickolas - Thanks for your input - however I did check and our Taurus does not have a security system installed, so that brings me back to square one with the blinking lights. I am sure there is an answer to this problem, but it seems to be eluding everyone including my two mechanics. I appreciate your assistance and hope that somehow I can resolve this very annoying situation.
CUDA66
Hello--my '99 Taurus (3.0L, 127,000miles) DRL's won't shut off when I turn off the ignition. They always have in the past, and I don't have the "Autolamp" time delay option...
I've removed the key, the headlight switch is off, I've tried disconnecting the battery (OK, they go off then, but come back on as soon as I reconnect it :D )...no such luck. I tried turning the headlight on/off switch and got them to turn off once, but then they turned themselves back on a short time (within 10 minutes) later.
Any help will be greatly appreciated. Thanks!
CHEVY22
  • 1,375 POSTS
Hi
i dont know how much help i will be , because you really need to do some checking on this type of problem , it could be several things including the drl module which is expensive , but for right now until you have it checked you can pull the drl fuse in the fuse box i think its #6 but double check , i just dont want to lead you down the wrong road , the drl module needs to be checked by a scanner
Jim
  • 110,251 POSTS
I need you to try something. Remove the flasher for the turn signals and tell me if the problem stops.
TAURUSWHEEL
  • 718 POSTS
I believe that drl module is located down on the frame, driver's side of the radiator.
NOS
  • 320 POSTS
it does sound like the DRL module is shorted to ground. it is mounted on the driverside inner finder well next to the frame it is a litte 3 in by 4in box unplug and see if the lights go out. 8) NOS
CUDA66
OK, thanks, I'm gonna give that a try..
And...how exepnsive is "expensive" when it comes to replacing it?
ANDYMAN002
Other Category problem
1996 Ford Taurus 6 cyl Automatic 161000 miles
where is the drl modual and relay for the daytime running lights
FLEXY5
  • 512 POSTS
I'm trying to remember exactly where it is. I Believe that it is in front of the radiator. If you remove the plastic cover over top of the radiator, you should be able to see it. It's about 5 inches square and about 2 inches thick. The relay is usually located near it.
let me know if this is not correct, I will try to get you a better location, but I think this is right.
