2006 Ford Taurus Computer went very dimm after programming
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
NEEDSMET
We have a problem on our 2006 Ford Taurus. A few weeks ago, our spare key was lost. Our mechanic took our car to a friend of his to try to get the key cut. His friend could not do it. So he took the car to a local Ford house. The ford dealer cut and programmed the key. The key works fine, but when the mechanic brought our car back, we noticed something odd. The computer that tells you how much gas you have, how much to empty an all that was extremely dimm. In fact, when the car is in gear, you cannot even see it at all. But when the car is in park, its back to its normal level of brightness.
The Ford dealer says that he did not do it. The mechanic says that he did not do it. If someone can give me some help with this Id appreciate it. What caused this and is there and easy and inexpensive way to fix it?
Jul 21, 2009 at 2:34 PM
RACEFAN966
  • 5,029 POSTS
Has anyone checked the dimmer switch for the instrument lighting? If not check that first and if that doesn't correct you problem then get back to me and we will have to do some tests to see what is causing it.
Jul 22, 2009 at 2:36 AM
