2006 Ford Taurus Air and Heat
2006 FORD TAURUS
81,000 MILES • 6 CYL • FWD • AUTOMATIC
MHEACOCK
Air blows cold and hot, but only blows through the defrost vents and only on high. All my other settings do NOT work. Is this a fuse or is it a deeper issue?
Apr 1, 2010 at 4:28 AM
  • 110,244 POSTS
You are looking for a vacuum leak problem. The vents are actuated by vacuum. The defroster is a default setting. Check under the dash for leaks. With the engine running, you may get lucky and hear a hissing noise from the leak.
Let me know what you find.
Apr 1, 2010 at 4:59 AM
