2006 Ford Taurus 20063 Ford Taurus will not start in the mo
DABAR101
MEMBER
2006 FORD TAURUS
6 CYL
FWD
AUTOMATIC
55,000 MILES
20063 ford taurus will not start in the morning, new starter and battery. HELP
Sunday, February 28th, 2010 AT 7:29 PM
BMRFIXIT
MECHANIC
Does it need to be jumped?
If so something is draining the battery
and battery drain test is needed to be done
SPONSORED LINKS
Sunday, February 28th, 2010 AT 7:32 PM
DABAR101
MEMBER
No battery drain, electrical all works aftera few turns of the key it will start
Sunday, February 28th, 2010 AT 10:55 PM
BMRFIXIT
MECHANIC
Check for security codes and check ignition switch
make sure shifter in park (push on it up or down as you trying to start )
remove and isolate ignition key from the other keys if have any on your key ring
