2006 Ford Taurus
54,689 MILES • 6 CYL • FWD • AUTOMATIC
PAUL WIGFALL
WHAT IS IT WHEN YOUR STEERING WHEEL SHAKES?
Apr 5, 2010 at 4:06 AM
  • 110,251 POSTS
Does it shake all of the time, at certain speeds, when you use the brakes...?
Apr 5, 2010 at 6:40 AM
PAUL WIGFALL
it shakes when you reach about 20mph
Apr 5, 2010 at 9:49 PM
  • 110,251 POSTS
Start with having the tire balance checked and have the tech check for shifted belts in the tires or a bent rim.
Let me know what you find.
Apr 5, 2010 at 11:33 PM
PAUL WIGFALL
thank you i will check these things out and let you know
Apr 6, 2010 at 5:08 AM
  • 110,251 POSTS
Hi:
Just a little info for you. If you feel the vibration in the steering wheel, it deals with the front tires. If you feel it in the seat and floor, chances are it is the rear tires. If you can differentiate between the two, try rotating the tires to see if it changes where the vibration comes from. If it does, then you have limited it down to two tires.
Apr 6, 2010 at 3:40 PM
