2000 Ford Taurus Steering Shaking
78,874 MILES • 6 CYL • FWD • AUTOMATIC
OLDBEAVER
Just got an oil change and had the tires rotated. I was told that there was movement in the front wheels and that I needed new ball joint? and tierod end?
Since then my steering vibrates and I am very concerned. I was told to take my car to another garage to have a qualified mechanic look at it.
I am ready to do this but since I am not a mechanic I want to know what is involved so that I can try to understand the repair he will recommend. Also would you suggest two estimates.
Thank you for being there.
Walter
Jan 20, 2008 at 11:08 AM
BMRFIXIT
  • 19,053 POSTS
[quote:f2f0b97db3="oldbeaver"]Steering problem
2000 Ford Taurus 6 cyl Front Wheel Drive Automatic 78874 miles
Walter[/quote:f2f0b97db3]
Loosing a ball joint or tie rod is not a fun thing
definite you should have the front end check by a qualified person
getting more than one opinion (always best)
note :
if you didn’t have the shake before the tire rotation and oil change
check tires and have them balanced
Jan 20, 2008 at 11:16 AM
