2006 Ford Taurus
2006 FORD TAURUS
86,000 MILES • 6 CYL • FWD • AUTOMATIC
TRAE WHITE
Still having problem with the lights flickering and rpms not holding steady. Have replaced fuel filter, spark plugs, and an air boot. Cleaned the idle air control valve and carb. Has clean oil. Check engine light is not on. Alternator and battery test good. Clean air filter. What could be causing this?
Nov 6, 2009 at 2:40 PM
BMRFIXIT
  • 19,053 POSTS
Check for vacuum leaks
start engine and try to check for vacuum leaks
remove battery terminals , check ,clean and retighten
Nov 6, 2009 at 9:02 PM
