2005 Ford Taurus transmission
75,000 MILES • 6 CYL • FWD • AUTOMATIC
JANMANZ
car seems to work fine,but goes into gear but wont engage in any gear,no leaks or clunks,any ideas??
Mar 28, 2010 at 6:28 AM
BMRFIXIT
  • 19,053 POSTS
Check for codes
I would suspect an internal tranny failure as it is very common for the pump to fail
Check shifter link:
engine off key on
E brakes on foot on the brake
Place shifter in R or D
Try to start engine (starter should not engage if shifter in any drive position)
No start shifter and links OK and it’s an internal tranny failure
check axles
check brakes
Mar 28, 2010 at 10:03 AM
