2005 Ford Taurus rear window defroster repair
58,000 MILES • 6 CYL • FWD • AUTOMATIC
TNYDLE
connector has come loose from rear window. this has happened before and was fixed by dealership for about $40 is there a way to purchase this connector repair kit and fix it myself, hopefully for less money
Sep 20, 2008 at 4:04 PM
JPIWARON
I was hoping to find more options than I did when I went searching and found this.
However, I'll share what I did find. www.frostfighter.com is offering repair kits to fix the problem. There's an epoxy formulation they claim most people use and there's a soldering kit offered as well. The important thing there is that you'll be applying a lot of heat to melt the solder. Apply too much and you'll break the glass.
As Elmer Fudd might say, "Be vewy, vewy, careful if you choose to actually solder"
I ordered an epoxy kit.
Nov 7, 2008 at 2:12 AM
