Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Taurus
Trouble Codes
P Codes (Powertrain)
P0300 - P0399
P0300
2005 Ford Taurus p0300
2005 FORD TAURUS
87,000 MILES • 6 CYL • 2WD • AUTOMATIC
YYWWRONALDO
MEMBER
The engine light is on in my car. And I got the code p0300. Is this a big problem and what can I do?
Aug 12, 2010 at 9:16 AM
Experienced Mechanic
You have a random misfire code which are caused by vacuum leaks and bad fuel.
Aug 12, 2010 at 1:20 PM
YYWWRONALDO
MEMBER
So what can I do to repair it? Thanks a lot.
Aug 12, 2010 at 1:52 PM
That's only a part of it that can be wrong also below
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Aug 12, 2010 at 2:17 PM
YYWWRONALDO
MEMBER
Thanks a lot!
Aug 12, 2010 at 2:45 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
