2005 Ford Taurus p0300
87,000 MILES • 6 CYL • 2WD • AUTOMATIC
YYWWRONALDO
The engine light is on in my car. And I got the code p0300. Is this a big problem and what can I do?
Aug 12, 2010 at 9:16 AM
  • 75,988 POSTS
You have a random misfire code which are caused by vacuum leaks and bad fuel.
Aug 12, 2010 at 1:20 PM
YYWWRONALDO
So what can I do to repair it? Thanks a lot.
Aug 12, 2010 at 1:52 PM
  • 75,988 POSTS
That's only a part of it that can be wrong also below
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Aug 12, 2010 at 2:17 PM
YYWWRONALDO
Thanks a lot!
Aug 12, 2010 at 2:45 PM
