2005 Ford Taurus morning transmission leak
114,000 MILES • 6 CYL • FWD • AUTOMATIC
EKG49
i have a rebuilt trans installed by aamco which is now out of warranty. after the car has sat out all night once it has started trans fluid squirts out onto the ground when i pull off. i am loosing about a quart and half each day. when i took it to aamco they could not find a leak.
Mar 8, 2010 at 6:51 AM
  • 110,248 POSTS
Wow! They can rebuild a trans but can't find that bad of a leak? If you are loosing that much and it happens when you start the car, it has to be the cooling lines. There are two, one that runs to the radiator and a return that goes back to the trans. Check them and let me know what you find.
Mar 8, 2010 at 9:16 AM
