2005 Ford Taurus Difficult to disengage from park
JPG1714
Electrical problem
2005 Ford Taurus 6 cyl Two Wheel Drive Automatic
My 2005 Ford Taurus recently has been very difficult to disengage from park. I have to apply extreme pressure on the shifter release button. I can turn the key a little farther and it disengages normally.
The cruise control has failed to work since this problem started. I have a feeling it is some type of fuse or electrical problem.
Jun 29, 2009 at 3:28 AM
BMRFIXIT
  • 19,053 POSTS
Suspect brake light switch
step on brakes and check if the brake lights on
check fuses
and wiring at the switch
good luck
Jun 29, 2009 at 6:07 AM
JPG1714
As i expected it was just the fuse. Thank you for your quick response.
Jun 29, 2009 at 7:40 AM
