2005 Ford Taurus compressor replacement
RICHEIL
Air Conditioning problem
2005 Ford Taurus 6 cyl Front Wheel Drive Automatic
What is the proper method to R & R a compressor assembly? If you remove the radiator fans will it slide out towards the rear of the engine?
Oct 16, 2009 at 12:54 AM
BMRFIXIT
  • 19,053 POSTS
what do you have for engine ?
both coolant fan need to be remove
Oct 16, 2009 at 11:49 AM
