2005 Ford Taurus AC compressor removal
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
TKFOSKEY
I have my compressor removed from the enigne but have yet to find a way to get it out. I need to find out what all has to be removed to get the compressor out.
Thanks a great deal
Apr 1, 2009 at 3:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
If your vehicle is equipped with the 2V compressor, perform the following operations to remove the compressor:
REMOVAL:
Remove the RH and LH cooling fans.
Loosen the tensioner and remove the drive belt from the A/C compressor pulley.
Disconnect the compressor manifold and tube assembly (discard the O-ring seals)
Disconnect the compressor field coil electrical connector.
Remove the four A/C compressor mounting bolts.
Remove the A/C compressor.
Installation is reverse of removal procedures.
If you need further assistance just let me know..
Thanks for using 2CarPros.com!
Apr 1, 2009 at 3:37 PM
