2004 Taurus 130,000
AVIAN5
I have a coolent leak that leaks when i pull out of my parking spot. There is a trail of coolant on the ground pulling out of my driveway and leaving my house. The trail itself doesn't last too long. I took it to the Ford dealership and they cannot find anything wrong with it even after a pressure test. I went ahead and changed the thermostat but that has not made a difference. It happens between 1 and 2 times a week. Sometimes it doesnt happen at all in a week.
May 24, 2007 at 7:50 AM
AVIAN5
My coolant lvl does go down, plus it leaves a semi permanent trail on the pavement from the chemicals of the coolant. There was one time where the coolant was pourring all over the ground and lost half my coolant.(this only happened once last 10,000 miles) Took it to the ford dealership, they did a pressure test and couldn't find anything wrong with it. I know for a fact that it is coolant. IF it was just water it wouldn't leave streak marks on the pavements that lasts for months afterwards. My only guess is that something is building up more pressure than the system can handle or some tubing is leaking with the heating and cooling of the day
Aug 21, 2020 at 6:26 AM
