2004 Ford Taurus Turn signals and engine light
2004 FORD TAURUS
68,000 MILES • 6 CYL • FWD • AUTOMATIC
AMASSAGE2ENVY
My turn signals stopped shutting off automatically, around that same time my engine light came on. I was over due for an oil change so I got that done and the engine light stayed on, I reset it manually by taking the post off the battery for a few minutes and putting it back on. It shut off the engine light but a few weeks later, the engine light came back on. Nothing "appears" to be wrong with the car. There are no leaks that I detect, not over heating, all fluids are fine. I run it thru the engine test via the button on the console and everything comes back "OK". Please help!
Feb 12, 2010 at 3:49 AM
BMRFIXIT
  • 19,053 POSTS
Need an OBDII reader to access and check for codes
Codes should indicate and direct you to the troubled area
Most local and national part stores can access and get you the codes
Once you get the codes and need more help let me know
If all directional don’t work check and suspect a fuse, a flasher relay and or multifunction switch
If just one side, check bulbs, wires flasher relay
Feb 12, 2010 at 8:54 PM
