2004 Ford Taurus Transmission Problems???
127,000 MILES • 6 CYL • FWD • AUTOMATIC
FORDTPROBLEMS
Hello 2carpros! I have a problem. When I drive my car, the cars Rpm raises alittle. But when that does that, my speed increases. Even when i dont hit the gas pedal. (Example: I pulled up at a red light and, I had my foot on the break and out of no where, my car wants to take off!) Also, when i drive, i dont know if its the transmission or not, but, i hear a *Thump* sound when i hit the gas. What is that? If it helps, my car died in the middle of the intersection and my fuel pump went. I replaced it and it still does it.
May 25, 2010 at 8:22 AM
BMRFIXIT
  • 19,053 POSTS
you have a vacuum leak or a bad IAC valve open hood and check PCV valve vacuum line
and also check for leaks
remove IAC valve and clean
if have check engine light on need to be scanning for codes
May 25, 2010 at 9:41 AM
