my car acted like it didn't want to move?
DONTAE06
Transmission problem
2004 Ford Taurus 6 cyl Wheel Drive Type unknown Automatic 110k miles
my car has never gave me any problems before but one day i was driven and my car acted like it didn't want to move so i turned it off and turned it back on and it wouldn't move i checked the oil and transmission and everything was fine the car will crank up and it sounds pretty normal but it just wont move i don't know what the problem is
Dec 14, 2007 at 11:09 AM
03TAURUSSUKS
Hi there I believe your problem is the Torque Converter. Check back out on the main board for my response to the post: "2003 Ford Taurus Won't move anywhere" for my answer to your problem. Hope that helps you out and good luck.
Dec 15, 2007 at 6:34 AM
  • 55,758 POSTS
It might be the torque converter but can I ask if you have checked the transmission fluid level? Here is a guide that can help you, also, I have seen the CV axle break causing this issue so please check that as well.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Fluid Types
Transmission Fluid Type
Type .................... Motorcraft MERCON V Automatic Transmission Fluid XT-5-QM
Capacities
Transmission Fluid .................... 13.0L (13.7 quarts)
Let us know what you find.
Oct 9, 2024 at 10:56 AM
