2004 Ford Taurus Squeaking noise
2004 FORD TAURUS
104,000 MILES • 6 CYL • FWD • AUTOMATIC
JOSHTURNER2311
My 2004 Taurus makes a loud squeaking noise while it is running. It started out quiet but is now really loud. It sounds like it is coming from where the cam shaft position sensor is mounted. I replaced it with no change.
Sep 4, 2010 at 6:22 PM
  • 110,194 POSTS
Are you sure it isn't the serp belt? Does the sound speed up with RPM's?
Sep 4, 2010 at 9:46 PM
JOSHTURNER2311
Yeah I'm sure. The sound is coming form the middle of the engine. I put a long screwdriver on the camshaft position sensor and my ear and you can hear the noise coming from it. What does the camshaft position sensor mount to? The car will also rev up a little on its on sometimes. That just started with the squeak.
Sep 5, 2010 at 11:55 AM
  • 110,194 POSTS
It mounts to the right front of the motor.
Sep 6, 2010 at 12:38 AM
