2004 Ford Taurus Speedometer
92,000 MILES • 6 CYL • FWD • AUTOMATIC
HAVEICE
My 2004 Ford Taurus has a speedo problem. Over the past few months the Speedometer has been reading faster than I am actually going. The faster I travel the larger the difference in actual speed and the speed on the speedometer (actual 65mph/reading 90mph). This was only happening once in a while and is starting to get more and more frequent. The transmission shifts fine and all other components are acting normal. I have owned this car since it was new and have had no other problems with it. Is this problem in the instrument cluster? Is there a speed sensor (not abs) somewhere? Could this be covered under the federal emissions warrenty?
Apr 5, 2010 at 12:41 AM
DOCFIXIT
  • 18,828 POSTS
Maybe cluster or speedo and could be Vehicle Speed Sensor. Would not be covered under emissions.
Need to have a diagnostic scan and testing done. So cost will depend on how much time a Tech needs to find fault.
Hope this helps
Thanks for donate
Apr 6, 2010 at 1:00 AM
